Hi, ok this time i'm won't be posting stuffs of my scratchbuild planes but the 3 FYP groups i'm currently helping.
I've been very busy with school works, projects,my own scratch build planes and my comming exams. Been helping other people's plane more then my own, but nevertheless it is more fun because they have the school budget,can do more expensive stuffs
FYP groups i'm currently helping:
1) Global Hawk 5m wingspan
2) SkyBox (Build according to singapore's skyblade UAV)
3) Solar powered glider
Number 2 and 3 have sucessfully madien, Skybox at woodland flying field while the solar powered glider is flown at Singapore Poly. Global Hawk had a "Lack of thrust" problem, will be madiening soon in a couple of weeks time in december.
1) Specifications of Global Hawk:
Electronics:
6s thunderpower 5000mah
100A hobbywing esc
GS Inrunner BL Motor B44-65-04 2060kv
120mm Haoye EDF
Dimensions:
5meter wingspan
Wingloading 18oz/ft sq
Weight 8.5KG fully loaded
2) Specifications of SkyBox
Electronics:
9s 4000mah voltron battery , 3x 3s in series
Phoenix-85HV esc
GS Outrunner BL Motor C63-62 320KV
Spinning 15inch wooden prop as pusher
Dimensions:
3meter wingspan
Wingloading 22oz/ft sq
Weight 11.5KG fully loaded
Specifications of Solar Plane
Electronics:
2s 500mah battery (as backup power)
20 x 0.7Amp 8V solar flim 12gram each
Esc (forget the specs but should be 30amps)
Axi Outrunner spinning 11inch prop (Can't remember the kv)
Dimensions:
1.5 Meter Wingspan
Clark Y airfoil white foam
Wingloading 5.4oz/ft sq
15degree dihedral ( i think its abit too much, but the whole plane is very stable)
Weight 1KG fully loaded
Electronics:
100A hobbywing esc
120mm Haoye EDF
Dimensions:
5meter wingspan
Electronics:
Phoenix-85HV esc
Dimensions:
3meter wingspan
Electronics:
Dimensions:
1.5 Meter Wingspan
