My 4th Scratchbuild mirage2000
    My previous experimental builds:
    RC groups original buildthread:
    Whoops! jet design contest-EDF Mirage 2000b build thread Electric Ducted Fan Jet Talk
    PDF version plans:
    DWG (for autocad) plans
    Yep... and heres the new one, sleeker looking and lighter. Completely built with white styrofoam.
    Specs
    -wemotec mini fan combo with 3900kv turningy
    -2200Mah zippy batt
    -40A hobbywing Esc
    -empty plane weight 150grams
    -AUW weight 600grams
    -Wings will be flat ,without airfoil.
    Plans are from www.parkjets.com
    Build it
    Fly it
    Crash it
    Fix it
    -Big white foamy blocks
    -Cut the Big foamy blocks into smaller chucks using hotwire
    -I have now many smaller chucks of white foamy blocks
    -Now i can start cutting out piece by piece
    Build it
    Fly it
    Crash it
    Fix it
      -But i can't start cutting without the templates so..
      -Draw templates on cardboard
      -Cut templates out
      -Pin the template on foam block
      -Hot wire the shape out
      Build it
      Fly it
      Crash it
      Fix it
        -Aligning the pieces that i've cut out.., looking good so far
        -Can't wait to glue those pieces together to see the overall result and shape of the plane!
        Build it
        Fly it
        Crash it
        Fix it
          -Cutting the ducting out from the fuse.
          -Thats where the ducted fan will be placed
          -100% FSA at the intake
          -80% FSA at the exit
          -tedious calculations and measurements are made to ensure the area smoothly decreases through out the whole tube.
          Build it
          Fly it
          Crash it
          Fix it
            -Glued the both halves together now..
            -Looking even better! very excited to get the whole plane done asap
            -Lazy to make a transparent canopy, so i just cut one out of white foam.
            Build it
            Fly it
            Crash it
            Fix it
              -Wings and tail stab are made of blue foam
              -Glued to the fuse and reinforced the joins to reduce wing flex
              Build it
              Fly it
              Crash it
              Fix it
                Alright,heres the end product! Sprayed with nippon paint silver colour. Yes..nippon paint, those that eat foams up. The reason why it didn't eat into mine because i applied a layer of protection before spraying it. (and that is also why you can see wrinkles all over the plane which is not really nice) Hmm..., not the best mirage2000 out there, but i'll practise further, improving my finishing!
                Now..., the fun part, to get this plane up up in the sky! Zoom zoom!.... Will update again when i manage to find time to fly it.
                Build it
                Fly it
                Crash it
                Fix it
                  What kind of protection u used?
                  Plane 1:
                  FreeWing F-15
                  Stock and modded with speed brake mod
                  Plane 2:
                  GWS Blue Angels C-130 (EDF)
                  Stock and modded with cargo doors
                  Control System:Futaba 9CHP 72MHZ
                    Nice work
                    Wah beautiful..... Want to see it fly...
                    Well done. can I come to your place to learn from you how to cut and glue and the fixing up?
                    regds
                    zennith
                      I don't really have time nowadays to do teaching , don't have time for myself to build planes recently or go down to flying field, having my school industrial training program now. I can do online teaching though ^_^. Simple for me. Any questions for me just ask away!
                      Ok..so to jieZ's question. The layer i put on is something like a tissue paper (no not those found in toilets) , Its those found in artfriend for arts & craft, very much like fibre glassing , but its thin paper and whiteglue instead of epoxy resin and fibreglass. It dosen't add any strength nor weight. Its just a foam protection... see picture and you'll get what i meant.
                      Anyway, Today was the madien day! went to school to fly and it went up up and away during the first toss!
                      -It wasn't fast at all
                      -very sensitive when fast
                      -stable when slow
                      -Barrel rolls were incredibly quick
                      -can do high alpha at a very large AOA without stalling
                      -and it's somewhat satisfying to fly
                      mission accomplished
                      Build it
                      Fly it
                      Crash it
                      Fix it
                        Congrat on your sucessful maiden.Reminds me of my previous M2000
                        Plane 1:
                        FreeWing F-15
                        Plane 2:
                          Dude,
                          Next Time Tamiya Spray paint.
                          My Hangar:
                          (SE-maiden 15/03/06)
                          (XL-maiden 16/10/05)
                          Heli 2:RAPTOR 50 TITAN
                          (TITAN-maiden 16/06/2006)
                          Heli 4:Flasher 250
                          (maiden 13/09/2010)
                          Transmitter:
                          JR 9XII(XPS 2.4)
                            Brilliant work Viper!
                            Maybe you don't have enough time to finish up your plane, but you should consider spending more time filling up the rough surface and finishing your planes.
                            To save money you might want to use water soluble emulsion paints like I did for my Tucano
                            Keep building!
                            Cheers!
                            Weelian
                              f117
                              haha nice today i just maiden my f117 at sp field.
                              damn nice lar i think u should try to build one.
                              the video.
